View unanswered posts | View active topics It is currently Sat Oct 19, 2019 11:23 am
Reply to topic  [ 1 post ]
 How To: XP Shocks on S or +6
Author Message
Owner/Admin
User avatar
My Ride: Yamaha XT250
Post How To: XP Shocks on S or +6
Let me start by saying my install is on a +6 SuperATV aluminum kit. With the Steel +6 kit or the normal "s" arms, you have to cut the lower shock mounts off and weld them on the correct location.
1. Remove stock shocks
2. Let you suspension droop until there is cv bind
3. Mount the top of the xp shocks
4. Lift up on the arm so there is no cv bind and then determine where your lower shock mount needs to be
5. Drill new holes or weld you lower shock mounts*
6. Bolt up the bottom of the shocks **
7. Drive your RZR and make adjustments to the shocks
* On the front I had to drill 1 new hole closer to the hub and the back I was able to use the stock holes
** I had to cut off the tabs that the plastic guard bolts to on the back shocks
Back lower shock mount showing the tabs cut off
Front lower shock mount. You can kinda see how I drilled a new hole to mount the lower mount further out.
Pics of the front and rear
On the trail
_________________
2015 Polaris Sportsman 850 Touring
2012 JK - 35" MTRs on 15" MB TKOs - Flat Flares - Trektop NX - RC Hybrid Stubby Bumper
RC RS9500 Winch - Rear Bumper/Tire Carrier - JKU Springs
1987 Chevy R10 SWB project truck
Thu Aug 30, 2012 12:59 pm
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Designed by STSoftware for PTF.
