View unanswered posts | View active topics It is currently Sat Feb 16, 2019 5:57 pm
Reply to topic  [ 7 posts ]
 300 king quad over heating
Author Message
Trail Beast
User avatar
My Ride: Suzuki
Post 300 king quad over heating
I have had this atv since 1999 and never had problems of overheating untill now. Still runs like a top when hot just hard to start and the header glows orange :flame I have been taking it much easier on it since I been having issues. But would like to get it taken care of before major problem occurr. I hear of people adding fans, but not sure witch would be safe for riding in water and mud.
_________________
2000 Suzuki king quad 300 4x4
high,low,super low
2wd,4wd,diff lock
IRS
2000lb super winch
needs tires!!
Thu Jun 27, 2013 9:21 pm
Profile
Site Admin
User avatar
My Ride: 2012 Kawasaki Teryx4
Post Re: 300 king quad over heating
Sounds like your running lean. Check the plug.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
_________________
2012 Teryx4. 2" Lift. MSA Elixir wheels. 29.5" Terminator Tires. Custom metal roof. 45w UHF 2 way radio. Totron 3"x3" cube lights. Jensen Marine Radio with 6.5" Lanzar Wake board speakers.
Thu Jun 27, 2013 10:21 pm
Profile
Trail Beast
User avatar
My Ride: Suzuki
Very well could be, nothing have been touched on it since day one, other than oil changes and changing plugs but it's been years since a plug was out. I will have my driving style has changed some I ride more on gravel roads at faster speeds than I used too. Planing on a ride Saturday, any idea on how to adjust the mixture if it is lean?
_________________
high,low,super low
2wd,4wd,diff lock
IRS
2000lb super winch
needs tires!!
Fri Jun 28, 2013 2:52 am
Profile
Site Admin
User avatar
I have no idea about that. Check the air filter and make sure it isnt clogged.
_________________
Fri Jun 28, 2013 5:56 am
Profile
Hill Climber
User avatar
My Ride: 2008 King Quad
2009 RZR
Also check ur spark arrestor, could be party blocked........
_________________
2009 RZR
"FRANK N RZR"
Full Tusk Skid Plate
3000# Wench
1 1/2" Wheel Spacers
27" Dirt Tamers
Fix It Shop Doors
Hobbs Windshield
Kymedic (Kenwood) UHF Radio
Kymedic 6+ A-Arm Kit
2008 King Quad 450
25" Mudlites
2500# Wench
Fri Jun 28, 2013 8:35 am
Profile
Hill Climber
User avatar
My Ride: 2015 Polaris 570 RZR
Jason those old Suzukis have a bad tendency to tighten the valves as they get some miles on em. The valve face starts wearing down and lets it open the valve too soon causing loss of compression. Usually it causes hard starting because of that. Sounds to me like that is your issue. I would adjust the valves and get them into spec before I did anything else to it because I bet that will fix it. I cant remember now if it is the intake or exhaust valve that wears down, but I think thats your issue.
_________________
2015 Polaris RZR 570
-14" Red/Machined No Limit Rims
-26" Maxxis Bighorns
-Moose Top
Mon Jul 01, 2013 1:19 pm
Profile
Hill Climber
User avatar
My Ride: 2007 Grizzly 700
Not sure if ya solved this, but a lean condition could be caused my a cracked intake tube (after the carb) or any place the engine can suck in un-metered air carb gaskets, any hole or crack in the intake path. The spark-arrestor clogged would cause the inverse, a rich condition.
I have no clue on C/D's valve recommendation but sounds like he knows his stuff or has history w/ the bike. This could also cause a lean condition maybe if the correct valve is stuck open at the right time.
If the header pipe is glowing, you are definitely running lean, and maybe close to melting a piston. Hope you get 'er fixed.
dw
_________________
Facebook: http://facebook.com/dougie.r.73
When you see a Grizzly, the spot where you see it becomes instantly different from every place else you've seen. Grizzlies make you pay attention.
2007 Yamaha Grizzly 700 fi
27x12 Kenda Bearclaws on DWT Diablo Beadlocks
Superwinch Terra 35 SR (front)
Warn/Yamaha 2.5ci (rear)
Solex Bars w/ Rox Riser
HMF Utility Series Pipe
Dynatek Ignition
HMF Optimizer
K&N Filter
Thu Aug 01, 2013 4:12 pm
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Designed by STSoftware for PTF.
