View unanswered posts | View active topics It is currently Sat Apr 20, 2019 9:01 pm
Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Snorkel Input
Author Message
True Redneck
User avatar
Post Snorkel Input
thinking of adding a snorkel to the honda sometime . any input ? im not one to go out & purposely try to kill the old girl but i also dont like to turn around either . ive had water deep enough to know i was close to my limit . ive been looking at the highlifter kits but im wondering if most people buy a kit or just piece one together themselves ? also the kit supposedly come with every little line & check valve you need for everything . its around 100$ , i know its mostly just pipe & tubes so a little advice would be great .
_________________
Aaron Williams ( AKA ) Dumplin
2011 RZR 800S
Fri Nov 25, 2011 7:05 pm
Profile
Owner/Admin
User avatar
My Ride: Yamaha XT250
Post Re: Snorkel Input
If you have time, buy a bunch of black abs from lowes and get to creating, and take back what you don't need. you might be able to find a parts list of stuff to buy. I will look around for you.
_________________
2015 Polaris Sportsman 850 Touring
2012 JK - 35" MTRs on 15" MB TKOs - Flat Flares - Trektop NX - RC Hybrid Stubby Bumper
RC RS9500 Winch - Rear Bumper/Tire Carrier - JKU Springs
1987 Chevy R10 SWB project truck
Fri Nov 25, 2011 7:09 pm
Profile WWW
Mudder
User avatar
I bought a Triangle Atv kit from highlifter for my 420 rancher. It came with everything you need to waterproof the whole rig. Also came with a detailed installation video. I talked to one of the salesman at highlifter, and he claimed the triangle kit had the highest quality parts of any of them. But you could also buy MOST of the stuff in the kit as hobbz said. I'll probably make me own for my backup 300, but I chose to by the kit for my first install and main bike. I figure they have done the research on what is best. My kit is 2 in. and on the FI 420 with a pipe and filter it is running great without a programmer. It was long but hopefully helpful.
_________________
2003 450 Foreman, 29.5 Laws on highlifter XL2s, 2" lift, HMF pipe, stick stoppers, 18% gear reduction, snorkeled, disc brakes, 26" zillas on ITPs
The wifes: 2002 450 Foreman, snorkeled, sportster muffler, STI HD2s and 26" Executioners
1998 KDX 200, bark busters, skid plate, FMF, gripper seat
Fri Nov 25, 2011 10:01 pm
Profile
Owner/Admin
User avatar
I think the triangle kit uses a flex hose doesn't it? If so, I have heard horror stories where it has got a hole in it and your snorkel becomes worthless....
_________________
Fri Nov 25, 2011 10:46 pm
Profile WWW
Mudder
User avatar
Yea it uses I think a spa hose. It has done great so far. Its very thick and reinforced, but I do have plans on covering the 6-8 in. that are exposed with a wire mesh just so I feel better about sticks on the trail. Its all a gamble anyway movement and vibrations could loosen the glue on pipe.
_________________
Sat Nov 26, 2011 10:45 am
Profile
Slow Rider
My Ride: Honda Rincon 680
I Just added a stealth snorkel to my 07 rincon and really like it, I found the way to run it off Rincon Riders.com under stealth snorkels search. It was real E-Z to install ,all the parts from Lowes for around $35 .You may want to check it out.
_________________
2007 Honda Rincon 680
26' itp Blackwater Evolutions,ITP 312 wheels,f/r warn bumpers,highlifter springs,wes industries rear seat,stealth snorkel.Full skid ,Led light bar
Tue Nov 29, 2011 9:26 am
Profile
Trail Rider
I Went to aruara spas in Lexington and bought some pool/spa hose and it's about 1/8" thick very strong I don't see a stick or anything poking through it. It was $2 a foot then just went to lowes and bought a bunch of random 90's and 45's with a 5' stick of abs pipe I think it was like $18. Right now I'm trying to figure out how many snorkels I want to run and where and how? I hope to haveit done this weekend when I get some free time.
_________________
06 Honda rancher 350 - 2" lift, 27" dirt commandors, 14" wheels, snorkeled, hmf exhaust and 24% gr next
06 yamaha raptor 700 - hmf exhaust and optimizer, +4" swingarm, flexx bars, nerf bars, 6 pack rack, dr. D reverse switch, and razr tires.
92 Jeep Wrangler YJ - 9" of lift, 37" mtr's, 4.10 gears, lots more
04 ford F350 Powerstroke - lots of goodies
Tue Nov 29, 2011 4:04 pm
Profile
True Redneck
User avatar
Post Snorkel Input
Sweet!
_________________
2011 XP900
Longhair Customs Cage
Longhair Customs Front/Rear Bumper
ZBroz High Clearance Trailing Arms
Dragon Fire High Clearance Radius Rods
Outkast Fabworx High Clearance Front A-Arms
Rhino Axles
Pro Armor Sniper Seats
SuperATV Steering Wheel
Racertech Hitch
Racertech Dual Rate Springs
14x8 ITP 112 Wheels w/28x10 Baja Cross Tires
3500lb Venom Winch
Kicker Sounds w/Sony Media Player
Kenwood UHF 2-Way
RCI Harnesses
Ridgid Industries 10" LED Light Bar and 6 Dually's
Longhair exhaust
Tue Nov 29, 2011 5:00 pm
Profile
Winch Breaker
User avatar
hobbs did you use the write up from the guy on rzrforums or did you come up with your own set up? and did you use abs? i think i might try to do mine this weekend
Tue Nov 29, 2011 5:34 pm
Profile
Owner/Admin
User avatar
i followed the one on rzrforums. it worked perfect. yeah it is the black abs. make sure you get abs cement/cleaner not pvc cement. the cleaner will take the writing off the abs too for a clean look
_________________
Tue Nov 29, 2011 5:40 pm
Profile WWW
Winch Breaker
User avatar
ok, did you find the abs at lowes or HD?
Tue Nov 29, 2011 5:46 pm
Profile
Owner/Admin
User avatar
bought everything at lowes
_________________
Tue Nov 29, 2011 5:47 pm
Profile WWW
Winch Breaker
User avatar
gotcha, thanks!
Tue Nov 29, 2011 5:49 pm
Profile
Trail Rider
I work for a insulation company and I think I'm gonna put 1/2" armaflex pipe covering on it for a cleaner look plus very easy to paint and protect from any engine heat or we have this stuff called 777 weather guard that's a 1/8" thick tar type adhesive with a foil jacket over it that I might wrap the pipe with that is under the plastics to make sure it's water tight that way if for some reason the hose or any abs doesn't hold up or comes lose a have a secondary adhesive to hold it together. Plus it with stands high temps also to protect from any engine heat and looks good!
_________________
Wed Nov 30, 2011 8:20 am
Profile
True Redneck
User avatar
thanks for all the input , gonna be a cold weather project in moms garage . prol consider a 2 in lift and maybe some wheel spacers and do it all at once .
_________________
2011 RZR 800S
Wed Nov 30, 2011 12:10 pm
Profile
Mudder
User avatar
Sounds cool. You can't mod them out too much. IMO :take
_________________
Wed Nov 30, 2011 7:01 pm
Profile
2nd in Command
I put a perfex suspension kit on my foreman and it gave me about an inch of lift and the ride was alot softer.
_________________
2014 Polaris Xp 4 1000
Emp roof and hardcoat windshield
Utv giant lower door inserts
Polaris rocker guards and cargo cooler box
2003 Honda Foreman
26" Mudlites
Perfex suspension kit
front disc conversion
1500 lb warn winch
Thu Dec 01, 2011 12:39 am
Profile
True Redneck
User avatar
I might have to look into that .
_________________
2011 RZR 800S
Thu Dec 01, 2011 11:15 am
Profile
True Redneck
User avatar
I just found a bunch of reviews on the perfex , could you tell a big difference in your ride ? These reviews make it sound great . Having trouble finding an actual web site for them .
_________________
2011 RZR 800S
Thu Dec 01, 2011 11:34 am
Profile
Hill Climber
User avatar
My Ride: 2007 Grizzly 700
Seen folks have luck w/ flexible PVC. Glues to the same fittings as the rigid stuff but is easier to get into the awkward spot. Probably the spa stuff that mentioned Csmyj ^ there.
dw
_________________
Facebook: http://facebook.com/dougie.r.73
When you see a Grizzly, the spot where you see it becomes instantly different from every place else you've seen. Grizzlies make you pay attention.
2007 Yamaha Grizzly 700 fi
27x12 Kenda Bearclaws on DWT Diablo Beadlocks
Superwinch Terra 35 SR (front)
Warn/Yamaha 2.5ci (rear)
Solex Bars w/ Rox Riser
HMF Utility Series Pipe
Dynatek Ignition
HMF Optimizer
K&N Filter
Fri Dec 02, 2011 5:30 pm
Profile WWW
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Designed by STSoftware for PTF.
